Hey,
ever had a shot that refuses to track on frame 1 of an auto stabilize? I do all the time. So today I reversed my footage, tracked that, then un-reversed.
Thought I’d share
Gareth Parry
Hey,
Thought I’d share
Gareth Parry
Don’t you have to set the start frame to 0 in the Auto Stabilizer for it to interpret frame 1 correctly? I might be wrong about this but I swear this worked in the past.
Hi Randy - you are absolutely correct - set start frame to the frame before FFOA.
I do that every time. This trick helps when the footage has a very fast move on frame 1 which means the tracker can’t get started. Of course you can increase flexibility but my trick avoids the need for that.
Gareth Parry
Ahh okay cool. Yeah that’s gotten me in the past. Thanks for sharing! Top tip!
I always get frame 1 to be a little off than the rest of the sequence
I think you can avoid that if you always take handles into the BFX/batch.
My frame 1 is always frame 9 if that makes sense?
