I never really know what settings i should set Flame too when importing my FBX camera scene from Mocha pro camera solve. I try auto fit to scene and its kind of OK but is there a vital bit of knowledge i’m missing here? Is there a scaling preset in Flame everyone uses apart from me. What trick am i missing or is it just trial and error? Thanks as always.
What do you wish was better about the scene scale after you import? Are you having problems once you’ve brought the FBX in to Flame?
If you hang the entire scene off an axis you can adjust the scale after importing. Annoying if you start adding a bunch more things to your scene but it does away with the “trial and error” bit.
I’ve never used Mocha’s camera solver, but when you track in Flame, unusually small or large scenes(relative to the actual scene) are generally an indication of a poor solve.
