MOCHA Issue With ML mask tools & 3D track
Hello there :slight_smile:
I’m experiencing issues with Mocha OFX on an M2 Ultra running Flame 2025.2.1.
I’ve been in contact with Boris FX support but we haven’t been able to find a solution.
  • The new ML tool for garbage masks isn’t working properly it selects almost the entire shot, regardless of the scenario.
  • Additionally whenever I switch to the 3D tab for SynthEyes, Mocha crashes every time.
I’ve already updated Mocha and cleared the cache but the issues persist.
Has anyone else encountered these problems ? Or had a similar experience with Mocha ? Any suggestions would be greatly appreciated !
Thanks!
I have the same setup as you, but I’m on Flame 2025.2.2. Everything’s working for me, maybe try updating Flame?
-Ted
I have just had an issue with this myself. You hit render and it moves forward making no spline. I may have a fix? I was in ACES so colour managed to rec709 as an input to mocha. I then changed mocha colourspace to legacy (OCIO legacy , working colourspace mocha working rec 709) It is now rendering my splines as it should. At least it seems to be a fix for now but this problem is quite random affecting some shots and not others. All shots are ACES so go figure?
