Everytime I use open fx mocha pro and come back into flame after exiting mocha ui, flame crashes. Happening to anyone else?
Which version of MochaPro are you using? There is a third library conflict between Flame 2025.1+ and MochaPro earlier than MochaPro 2024 (release 11).
Got it. Thank you. I versioned up and it worked
Hey friends! I’m also having this issue except I’m on Flame 2025.2.2 and I’ve updated to the latest Mocha, but the problem still persists. Occasionally, if I save Mocha multiple times and exit via the file menu, Mocha will quit cleanly, but the other 80% of the time the “Mocha is starting” window locks me out of Flame.
Any help you all can provide would be amazing.
Thanks!
I had a similar problem and the culprit was having motion blur turned on in Mocha. Turned motion blur off in Mocha and all was fine.
