After discussing MotionVectors from CG I wondered how they actually work, and here is the answere to that question at least for Blender/Cycles:
The Vector pass is 4 channels (RBGA) and are containing this:
- Vector.X - X displacement from previous frame to current frame
- Vector.Y - Y displacement from previous frame to current frame
- Vector.Z - X displacement from current frame to next frame
- Vector.W - Y displacement from current frame to next frame
Values are in pixels. X displacement is positive to the left, Y displacement is positive downwards.
So now flame seems to expect R and G channels to be flipped and it doesnt account for the Y dispacement in the alpha channel as it only takes one RGB pipe for the vectors?
Did a bit of experimenting here.
Left: Motion Vector Blur out of Blender (simple setup)
Right: Flame’s (Flame is nicer!
… not sure)
In Nuke I did a bit of reshuffling and set the motion channels to RGBA… although I think Flame just uses RG for UV absolute values
Pretty sure the reshuffling can be done in Blender’s Compositor… will try that later
Blender shuffle:
Testing Blender output on the left
you can also reshuffle in flame using mono and combine nodes
I wonder where not using “Y displacement from current frame to next frame” can give us issues.
I could not get the vector to work straight out of the Blender render… hence the reshufle.
I am guessing it is because the WXYZ channel name fuckery
I still put my Blender output through the compositor anyway. Usually for AOVs denoising… but even just to rename the channels, as Blender default naming is ugly.
interesting I thought it was a bug with my particular render, I also get that same error in flame (look at the log it struggles to decode it
