Moving segements to another track
Hello
copied (copy/paste) a clip from one reel to another, in order to make some modifications.
Unfortunately this process shifted the yellow marked segments to track V1.2 :frowning:
How can the 5 segments be moved back to track V1.1 without having moved the subsequent
segments of track V1.1 and V1.2 ?
Thank’s a lot!
its probably because you have Ripple activated on your timeline.
I leave Ripple off because its too easy to screw things up further down the timeline without knowing you have shunted stuff until its too late!
Thanks a lot Lightningad, with Ripple off it does work perfectly :slight_smile:
