New FLAME CAPSULE - Exporting a single frame from a sequence - Flame 2021.1
Good day everyone!
Today’s 30 second Flame Capsule shows you a great little workflow on how to export a single frame from the sequence.
Very quickly mark up your frame in the sequence and just export between the marks with your preferred format.
Great reminder if you haven’t done this in a while and extra workflow to have in your back pocket.
Stay safe and hope you have a great day!
Solid tip. Thanks for always posting these here! Time to make use of these forums and open up the discussion!
Another very related feature that I only (relatively) recently discovered is Poster Frame. Same idea, different way of doing it. It exports a single frame of your choosing in a single sequence or many sequences. The beauty of this one is if you have to export a large number of stills and you know you either want the first frame or a frame after a set number of handles, you can set that and export them all without setting any in / out points.
The first few times I had to export 100+ stills from shots for spreadsheet creation, it was a very manual process… but never again!
That’s a great feature, however I cannot make it work with a sequence of shots. It only exports 1 frame. Does it work on all shots in a sequence or do I have to export all shots separately at once.
Great question John. In re-reading that tooltip description, I can see where you’re coming from. I think when I first wrapped my head around how this feature works, I must have jumped to certain conclusions without reading that tooltip, because it seems very clear from it that if you have 10 clips in a single sequence, and you export a poster frame for that sequence it should export 10 poster frames. Either both of us are missing something or that description is incorrectly worded.
The way I’ve used it is by selecting several sequence at a time, and getting a single frame per sequence. In the specific case I mentioned above of having to export single frames for 100 shots, I had taken my Sources / Shots sequence, matched out all 100 shots onto the desktop, selected all of those shots, and THEN selected “Poster Frame” when I went to export.
That’s what I did and it worked a treat. I might put a feature request in to ADSK to be able to export a poster frame of each clip from a sequence and that way we can label each frame with a token too that refers to the sequence.
That’s really neat. Another hidden gem.
Perhaps you could choose via a marker?
Hi All,
Thanks for the replies.
My intention of the video was to be able to export a single frame from the sequence. Any chosen frame with the markers to be exact. That was my reasoning for saying “exporting a single frame from a sequence”.
In a lot of the other apps I use, there is always a “save frame” option which saves what you currently see in the viewer and I was essentially finding a Flame equivalent. Hope this clears up any confusion.
If you are after more then that then there is the poster frame option but I need to speak a little more with the designers on how it works.
Please feel free to file the requests via Flame feedback.
Thanks
Grant
It would be great if rather than an explicit, hard-wired reference you could export the first, last and or middle frame.
When exporting a frame I always use Control+G to grab a frame then open my reference panel. Right click and choose export. This is in my opinion a much overlooked feature. I use it a lot. Grab a frame, and even drag that frame back in a batch setup to compare or match things. Try it.
i use this all the time. i wish you could carry the shot metadata with it, that would be even better.
Then there’s me over here, just setting a hotkey for Repeat since 2003.
@TimC - ? If I press CTRL-G I get these options…
There also preferences for Reference Frames:
Reference Preference…
ohhhhhhhhhh - I just discovered a feature request:
<timecode> and <frame> would be useful tokens for this feature and are not currently implemented.
FI-03415 Reference Frames - request for <timecode> and <frame> tokens
You can use the Start Frame option when exporting to get access to the frame number, e.g. if I choose to export frame 1078 from a sequence that starts at frame 1001, but this has the potential to be ambiguous.
I guess all kinds of temporal tokens would be useful here, source timecode, record timecode, frame, etc.
I use a python hook called “export frame”. It works great. It need perform a little setup in flamemenu>logik>logik portral script setup to setup format file and default path.
Overlaps with an old request of mine:
FI-02682
This would be mildly life-changing for us!
I use this too. I have one for tiffs and one for jpegs. Someone with more python skills than I could probably modify it to do first and last frame as well
@cicero - i upvoted
