Thanks for the feed back
Im using Flame on Linux and dont see anything that would allow to convert the output intensity in animated R G B channels (Animation Tab). But maybe im missing something. Just to be sure that we are talking of the same thing, Im looking for a value variation data in output, like if we, for example, select Average, we could get, as a result of the ROI analysis, a yellow line under squares that returns the average of R G B Values variation through time, and then do some expressions with it.
Yes, that exact thing is working in Resolve. I’ll find some time in the next few weeks to test it in Flame Linux and get that working.
This works in Flame in Linux and bakes the flicker values out so they can be used for expressions.
www.ericmlevy.com/vfxtools/flickermatch/FlickerMatch.ofx.bundle_0210.zip
Use Case 1:
Put your Flickery clip into the main socket, turn on Output Animation Channels, press Play. It’ll bake out the values.
Use Case 2:
The Flicker clip goes into the Green analysis socket.
The “I want this clip to Flicker” clip goes into the Main red input socket.
Let me know if it works and I’ll get around to building for Mac.
It works! Thank you it is very usefull. A build for mac would be amazing too !
