After Batch render I enter the “Player” for review. While in the module I used to be able to look at other “context” views. It recently just quit working. Does anyone know how to get the ability to work again? Thanks.
I was not aware of that feature. I presumed that once you went into the player you were in a different module ![]()
You can play the clip back inside of batch but I don’t usually do that. I will take a look. I have just moved to Flame 2023.3 What version are you using @visionmimxer?
2023.1
It used to work. I’m guessing I accidentally hit some hot key that turned it off.
Thanks.
