Point Cloud Snapping - Original Mono Analyzer
Is anyone else finding that snapping to points in the Point Locator cloud generated from the mono analyzer no longer working? We used to be able to snap the vertices of an extended bicubic to them which was super handy for shaping surfaces into geometry to project onto for clean up work?
4:50 in this tutorial from back in 2014 shows the functionality I’m referring to:
Hi Jamie,
You need to go to the Action Preferences and choose the Display menu. Here you will see an option called Snap Z Position. It is on by default . Turn it off and you should be able to snap to the point locators as before.
Amazing. That does the trick. Thank you very much.
