Surface snap sensitivity in the old 3d tracker
Hi all,
Snapping your surface to a locator in the old 3d tracker doesn’t seem to work for me anymore. Is that the same with everyone else? (i’ve turned the tolerance up to 55 btw!)
TIA
did you activate the snap Z position in the action node prefs/display?
This is a known issue. It’s likely a double-assigned hotkey, as discussed here.
Amazing that worked, thanks @randy!
snap z position seems to be on by default for me, thanks Fabian!
