Snap corner pins to Axis?
Following Lewis Sanders great find-a-point tutorial. All good but stumbled with thye whole locator snap thing. I brought in a locator but nothing snaps to it. Is there an easy way to snap the surfaces corners to any axis or locator in 3d space?
-Best
In action preferences in the actual node there a snap toggle u turn off, unintuitively and it should work if you hold down shift while dragging the axis u want to snap from
Thank you Joel, Ill try that now.
It may have been fixed but for a long time the “shift snap to locator” hotkey was also being used by “shift snap to z depth” and the only way to make it work was to disable the zdepth one in the hotkey editor. Worth looking into if you’re still having trouble.
