Pro Res slight shift
Hi
I’ve exported a pro res 4444 back to the grade and they are saying there is a minimal shift. The highlight looks to be the worse affected.
Is it purely down to the export? They gave me a 4444 file.
Edit I’ve compared the files and it is miniscule but you can see a difference on the scopes but its TINY
Step 1. Difference matte the source and render in Flame. Do those match?
Step 2. Check the NCLC tag in the Media Hub. If that’s new to you, in the Preview area, under Metadata / Video Colour Encoding, what are the Primaries/TransferFunction/Matrix set to of your source? And Export? Do they match?
