Project: Error writing to database
On 1 of 3 flames I am no longer able to open the projects properly.
The system will hang on the step “volumemgt : Initializing” and eventually give the Error Message: Project: Error writing to database
Screenshot 2024-09-09 at 6.49.23 PM
I am able to eventually get the projects open and had our flame artist export the archives he needs.
If we try to switch projects from within flame we receive a different error message:
Locked Project Database lock held by: Unknown 15051, on: flame3hostname. Retry?
Screenshot 2024-09-09 at 5.01.42 PM
So far we have tried just about every troubleshooting step we know:
  • Rebuilding stone wire database from mirror
  • Removing all .Ref* files from /opt/Autodesk/clip/Stonefs
  • Removed all lock files from /opt/Autodesk/user/username/tmp/
If we try to to open the project of flame 1 (the problem machine) using another working flame we get the following error:
It sounds to me like our database is some how locked and thats why we cant write to it.
Any ideas whats going on, how to resolve this?
update: mac os 12.7.6 flame 2023.3
@MagicMtn - I don’t have an answer but I’m curious if your setup is Linux or macOS?
It helps to have a version number with questions like these.
I assume rebooted as well?
That 15051 is most likely referencing a process id, or less likely a user id.
If you rebooted this may no longer apply. If you didn’t, I’d try
ps aux | fgrep 15051
and see if that exists and if so if you can kill it.
@MagicMtn - are all flame versions at the same level?
Have there been any pre-release versions installed on flame 1?
I think the last version certified to run on an imac pro was the 2021 series. Anything newer than that might give you troubles.
Flame version 2023.3 on mac os 12.7.6
its worth noting flame 3 recently had 24.2.2 installed perhaps thats part of the issue?
all of them are on flame 2023.3 mac os 12.7.6
flame 3 recently had 2024.2.2 installed on it.
funny enough the imac pro is not the system giving us problems but it is the system flame 1 thinks the database is locked to i guess.
Pretty basic pretty obvious but, is your sw partition writable or read-only?
Mac OS
yes
Have you tried by sw_restart? Also check this in System Preferences on Mac and Confidentiality / Full Access to disk.
You have to allow : Flame / sw_dbd / sw_serverd / ifffsWiretapServer / Wiretapgateway.
Checking to see if Flame had Full Disk Access was my next guess as well
Thank you for your response i ran that command on both flame 1 and flame 3 with the following results:
Screenshot 2024-09-09 at 8.29.28 PM
not entirely sure what I am looking at or what command i would run next
kill -95587?
or
kill -72285?
I should have included that but we checked this as well.
What do you mean.
I have checked to make sure I am allowing all those things, and I am…is swrestart a command I can run to reinitiate that process?
we have rebooted mutiple times on both machines
That command also finds itself. So there was no process running with that pid.
No solution there.
we have restarted stone+wire from the service monitor mutiple times as well… is this the same thing as running the sw_restart command?
