QuadTone like in Sapphire
Hello everybody !
Is there any solution to make quadtone images ?
I see the Matchbox crok_2color.glsl or Duotone.mx but not quadtone.
Here is the GLSL 2 Color matchbox :
uniform sampler2D source;
uniform float Amount, Exposure;
uniform float dark_low, dark_high, light_low, light_high;
uniform float adsk_result_w, adsk_result_h;
uniform float brightness, contrast, saturation;
uniform vec3 light_tint, dark_tint;
vec2 resolution = vec2(adsk_result_w, adsk_result_h);
const vec3 lumc = vec3(0.2125, 0.7154, 0.0721);
void main(void)
	vec2 uv = gl_FragCoord.xy / resolution.xy;
	vec3 original = texture2D(source, uv).rgb;
	vec3 col = original;
	float bri = (col.x+col.y+col.z)/3.0;
	float v = smoothstep(dark_low, dark_high, bri);
	col = mix(dark_tint * bri, col, v);
	v = smoothstep(light_low, light_high, bri);
	col = mix(col, min(light_tint * col, 1.0), v);
	col = mix(original, col, Amount);
	vec3 avg_lum = vec3(0.5, 0.5, 0.5);
	vec3 intensity = vec3(dot(col.rgb, lumc));
	vec3 sat_color = mix(intensity, col.rgb, saturation);
	vec3 con_color = mix(avg_lum, sat_color, contrast);
	vec3 fin_col = con_color - 1.0 + brightness;
	gl_FragColor = vec4(fin_col, 1.0) * Exposure;
Maybe it’s not too complicated to do it with 4 colors…
If anyone has a tip to reproduce it in Flame :slight_smile:
Thank you
Shiver
Is it not the same as doing a uv map using your quad gradient as your color input and the luminance of the image as the uv?
@milanesa The gradient version works really well! Nice solve on that. With the gradient it becomes a little difficult to soften the keys like you can in the spark, hence my post above as an alternative. Depends on how much you want to mess about.
Hello Milanesa,
It’s a good trick ! Thank you.
Hello Johnt,
I tried as you did to do Keys to separate whites, HL, middle tones, shadows and blacks without any good results.
I just want to normalize color ramp on an image like i had to do with some clips for a job.
Thanks again for posting this! I am using it today to redo a mural/portrait made out of Rubik’s Cubes!
Thats amazing :scream:
thank a lot amazing .
Bringing back this trick - but what is this UVWarp node…? Is this a matchbox or a spark?
I love posting and then fixing my own problem…
I was able to do it in Action. Gradient as the diffuse surface, and the mono image and the UV map attached to it.
I wouldnt mind doing this not in Action… LMK if anyone know where to find the UVwarp node :slight_smile:
Thanks :smiley:
Hiya Ezmay- I believe the history is that the UVWarp32 Matchbox shader was one of the matchboxes that shipped with Flame and was one way to execute STMap / UV Map such warps before the introduction of the STMap node.
This is why if you’re looking for it now you won’t find it unless you’re going prior to 2025.
“The UVWarp32 Matchbox shader has been replaced by the STMap node.”
Thanks so much Jeff!
