Random Flame UI freeze?
Interesting.
Yeah I will test it thoroughly, it def seems quite clunky, but works, I tested it with proteus model and it worked. It seems to be missing the Rhea model, which is the latest and best, so thats a shame. Also the output is the same res as the input, so if you wanted to go from HD to UHD you would need to run the HD through a UHD resize node set to center crop, then run that through the topaz OFX so then the HD fills the frame. Anyway yup I will be testing this extensively and will report back.
