Render node replaced by matchbox
I just recalled a batch setup using the load and append in batch and the render node was replaced with wireless matchbox.
Has anyone else encountered this?
@johnag have you been smoking those beta versions again?
Is it only the icon on the node that has changed or there is really a Matchbox node where you thought a Render would be?
  • If it’s the former I would restart the application to see if it fixes the issue and keep and eye open to see if the problem occurs again.
  • If it’s the latter I would recommend sending that setup to support so they can investigate.
It was just the label and after a restart I havent seen it again.
