Whole scene created in batch and views correctly there, come out to timeline, render and get the timeline view rendered? Anyone come across this and have a solution?
I haven’t seen this specific one but whenever I’ve had UI burned in to renders its been related to motion blur, perhaps keyframed. I would check that first
It also looks like you are using a batch fx, maybe try use a render node inside the BFX and render to your library/reels
Wondering if it is based on an old action bug, that autodesk already had fixed in 2022 or 2023.
If that action reset helps, it might be back in a few cases, hope it wont.
