Restoring Flame Archive from CLI: Destination path required?
Hello,
would like to restore a Flame Archive (created on Flame 2021) soon* to Flame 2025 (I did not yet update to Falme 2025).
The following command does list all Flame projects but not where they are stored in macOS filesystem.
/opt/Autodesk/io/bin/flame_archive -l
Question:
Does the following command automatically restore the Archive to it’s proper location in the filesystem?
/opt/Autodesk/io/bin/flame_archive --restore --archive <archive_path> --project <project_name>
PS 1:
In macOS Finder the Flamestore is mounted on /Volume/Framestore
Here’s the Help page for command line archiving:
From the Examples section:
Restore project prj1 from archive arch1
flame_archive -r -F /tmp/arch1 -S '/Archive Session - 2014/03/12 23:43:40/prj1'
I would highly recommend you unarchive via Flame’s interface, it will make your life a lot easier.
-Ted
Thank you very much, Ted, for the wise suggestion !
