Sapphire not showing up Flame Linux
Hi all. Trying to get Sapphire up and running and it’s not showing up in the OFX node.
I run the following command to install:
rpm -Uvh https://cdn.borisfx.com/borisfx/store/SapphireOFX-11.040-1.x86_64.rpm
It says it installs correctly. It creates a folder in my OFX directory. But it doesn’t show up in the OFX node.
I’ve tried deleting the plugin cache xml. We’ve tested this on CentOS 8 with Flame 2022.2 and CentOS Rocky with Flame 2023.1.
Does anyone have any suggestions for this?
Hmm. I’ve only ever manually downloaded and installed and used…
rpm -I .rpm
And that works. Did it yesterday. The other question I have is Sapphire OFX Version 11 something? We’re on 2022 something now, so, is that like a 10 year old version of Sapphire you’re trying to install?
Thanks Randy! Yep for some reason the article on the Boris website was pointing me to the old installer. I tracked down 2022 and it’s all working now. Cheers!
