Copy Shot Name to Clipboard v1.0.0
self explanatory
on Logik Portal or github
Render Selected Nodes v1.0.1
Just box select the output nodes (Render or Write File) you want to process and then right click Render... > Selected Nodes. I find this faster than rooting around in the Render List.
Filter Selection v2.1.1
Quietly added this a while ago, forgot to do a write up. It takes what you have selected in the Media Panel and helps you drill down to a smaller selection. So say you have all 100 masters on your desktop, but you need to post only the 9x16s… just select the whole lot, right click Select... > Filter Selection, enter 9x16, hit Ok or mash the enter key. Now only the 9x16s are selected. It filters based on the name, so you would have had to have 9x16 in the sequence name.
Its similar to Search in Media Panel but I find this faster. The narrowest search you can have in Search in Media Panel is Desktop, which I find too broad usually.
