Slip footage in timeline, keep curves
What’s the trick to slip footage in the timeline but keep all the animation curves the same? I have everything the way I like but the in/out point needs to scoot. Thanks!
Hi @digitalbanshee
To slip the footage and not the keyframes, you need to change change the keyframe move mode from SHIFT to PIN. It is the pull down menu that is next to the SNAP button by the editing tools on the right.
Screenshot 2020-09-09 at 18.33.50
Thanks
Grant
Thank you Grant!
I am so happy you are here Grant. I never knew what that menu did!
