Smart Replace
Smart replace in batch - for some reason it’s stopped working with my batch - is there a way to reactivate it?
Try adding a new render node? Or make a new clean batch, copy all but your old render node into it?
If I remember correctly, in a video on Logic TV, it was suggested to store the initial batch iterations, and if “smart replace” masses up, to copy the final state of the batch tree back to this initial setup and render it from this unaltered render/write node and its original setup.
Edit; video I mentioned is here
it is about publishing so about the write node. however I have a strong feeling that same thing can be applied to render node when it can’t do smart replace.
