I did a presentation on LogikLive 170 that covered uses for depth maps, among other things. There, I showed the matchbox I made to remap the depthmap gradient to be a bit more stable between two given points on the image. You track two axes of the RGB video, one for the deepest point and one for the closest point and the matchbox remaps your depth gradient between these two.
Others are:
sv_Depth_Temporal_Stabilizer
sv_Triangle Mosaic - (works as a transition on the timeline)
sv_Digital Screen
sv_Voronoi Scatter
I developed these with the help of Claude, out of necessity. They all solved problems I faced. They can be downloaded from logik-matchbook.org. They also should point to my github where you can find read_me files and links to videos when available.
There are a ton of tools out there that we as artists have developed, and you can probably roll your own but, these are available if you need them.
