Hi,
Just wondering if there’s a node that’ll strobe / reduce the refresh rate of a clip?
So something you’d use if you were going to fake CCTV footage maybe, where the image refreshes every couple of seconds for example
Hope that makes sense, and thanks in advance!
philm
2
Use the deal node
And the repeat node
Or you can use the desktop tools
Or you can add an expression to affect the slip on a mux node
Or you can use timewarp
There’s a strobe setting in timewarp
Amazing, thanks both, I will have a play with your suggestions!
