Hi all,
Has flame changed the way it handles subtitle xml’s from 2021 to 2022.
Can’t get anything to import in 2022, visible in the media hub but not valid for import.
Same file in 2021 works perfectly.
I just had a look and I’m running into the same issue when trying to drag an xml over to the media panel. But if you hit the import button in the bottom left of the media hub with the xml selected, it works.
Thanks Mike,
Yes I was using drag and drop as it used the work that way.
Good to know import works.
