hi all. has T click changed. im in batch and doing what I usually do and T clicking the source clip to get the timecode to transfer to the render out and nothing. wont do it. tried loads of different clips. tried the collapsed render out and the expanded one. google says it should work. latest software on a Mac with latest OS.
Make sure the Render node is not set to Use Input Values in the Node Prefs submenu.
You can set it to Custom Values by default in Preferences - System - Batch & BFX
Perfect - thanks Fred. Hidden menus huh! shouldn’t that be overwritten if you hit T click??
Hey Jon- that behavior has changed slightly with the introduction of the new 2027 Metadata features. When you’re getting that Basic Metadata sent through the schematic, it’s populated into the Write File Node from whichever Clip node is hooked up upstream. You can still T-click if you set the Write File Node back to Custom Values like Fred said.
4:21 is the section talking about Basic Metadata changes.
Thanks Jeff. I do wonder whether a T click should auto override that setting, as there is only one reason you would T click.
But surely T click doesn’t need to exist anymore
You should have been there during the beta… it almost did.
