Got this since 2025, anyone?
In doubt, search the doc!
Set you Graphics Refresh to 60Hz and you should be good to go.
@Slabrie Somethings in the doc, maybe should be ignored though?
@ALan I looked into the documentation blurb you reported and, in my opinion, it is fine.
I could only find an instance of that text in the Configuration and OS page of the What’s New in 2025 section, which was true at the time.
An update on these two items was made in the What’s New in 2025.1 section, inside the AVIO Updates and Configuration and OS pages.
We do not usually modify the content of the What’s New section once published because, for example, a user may update to 2025 instead of 2025.1. In that case, the 2025 application may not have been set to use these components even if they are now supported on that OS.
