I thought there was a way to timewarp an audio track the same as the synced video track is timewarped. But I’m seeing no way to do this. I don’t even see a way to keyframe audio speed manually to match. Ideas?
My memory is that you can do constant speed timewarps on the audio. The render quality is sometimes not so great though.
You should be able to select an audio clip on the timeline and click the FX button > TimeWarp.
Also if you have ‘Auto Timewarp’ turned on in the Timeline prefs, when you make a 4-point edit where the record duration is different than the source, it should apply a Timewarp to both the video and audio.
