is there a filter equivalent to photoshops polar coordinates filter or a workflow how to create a tiny planet effect from a panoramic image? I found a youtube tutorial for photoshop using this polar coordinates filter but I have no idea how to do it in flame.
there is a tiny planet matchbox (Ls_Tinyplanet) with some parameters to play around with, but it needs some try&error: it’s not as fluid as the polar coord. variant.
I checked the other day that Ls_Tinyplanet can actually make stuff like the above from some environment HDRs and it worked fine, but admittedly I was also like ??!??? why did I label the controls like this 9 years ago or whenever it was - lmk if anyone has suggestions about how they should actually work
