UltraStudio 4K - No audio in Flame 2025.2.2
UltraStudio worked fine with Flame until today. I haven’t edited in Premier in a while and started a new project, everything was fine. Went back into flame and now I can’t get any audio out of Flame 2025.2.2. It works fine in Premiere and Resolve. I have powered down UltraStudio, double checked Flame setup and Desktop Video setup, nothing is working. I’m sure there is something Flame isn’t liking. Any ideas?
Made a new user and it worked fine. :neutral_face:
sounds like you mistakenly hit Toggle Audio Monitoring. It’s a shitty hotkey that…you guessed it…disables Audio Monitoring.
Alt Smoke A in Smoke Hotkeys. If you are inferior and use the suboptimal Flame hotkeys, search for it and give it the world’s most complicated hotkey to avoid this next time.
That was probably it. After I made a new user and changed back to the old user, it worked fine. Thanks!
