Virtualhere Rocky 9.5 (sunshine/moonlight)
I looks like rocky 9.5 is not compiled with vhci_hcd which causes virtualhere to not work, i wanted to use it as a teradici replacement
  1. HP is ghosting me , not getting a license, or a trial, or anything , they just dont react to anything …
  2. DVC is a no-go after messing with it for too long, hotkey issues e.t.c.
Moonlight/sunshine seems the most easy and solid for remote desktop on linux, hotkeys work, playback is insanely good, sound works - bitrate is good, no 4:4:4 but i can live with that I guess for now… single screen only but thats all still very doable as my broadcast gets out via ultragrid anyhow.
So i wonder, has anyone gotten VirtualHere working with rocky 9.5? any workaround?
Just dnf install vhci_hcd as Randy showed in the other post.
Schitts Creek Thank You GIF by CBC
love you all thanks
so whatever the pcoip installer installs makes it possible to install that kernel module?
crazy
curl -1sLf https://dl.anyware.hp.com/DQc5UQL6NpoGOd0u/pcoip-agent/cfg/setup/bash.rpm.sh | \
sudo distro=el codename=9 bash && \
sudo dnf install -y \
pcoip-agent-graphics \
usb-vhci
for reference.
epel-release and enable crb
Just a reminder than modifications done to the OS prevent us to support your configuration in case of challenges. But you already knew that, right ? :wink:
but if it gets installed during teradici / anyware / which is a supported thing - it should be ok right?
But yea i am not counting on anyone supporting the wild things that i am doing :joy:
It should be fine if the HP Anyware installation adds some package since we can validate that on our side. But that would be a package installation and not a kernel upgrade.
