shiver
February 23, 2025, 9:40pm
1
Hello everybody,
I have issues in Action with imported models I made in Blender. Not just this model but a lot.
The model seems ok in Blender and topology normals too.
Hardware AA : 4x
Antialiasing Software AA : 4 samples
I wonder if it’s ok to import models avec relight them, play with PBS maps, reflections etc. and get a final production level render look.
It’s not a very big project so I don’t want to make animations and renders in Blender and import them to Flame to compose them but this made me think about the workflow.
Waht do you think ? What is your way to make motion design all in Flame with 3D objects ?
thank you
Maybe Flame prefers triangles over quads?
Other than setting the antialiasing to 96 and praying I don’t think a lot will help. Maybe setting your clipping planes close to the model…
For all the amazing stuff that Action does, when it comes to 3d rendering it’s basically a game engine.
And to answer the second question: I mostly don’t do motion design in flame. I’m rather bad at it.
Sinan
February 23, 2025, 10:18pm
4
3D objects in action! YES! I love it.
Here are some simple steps to get you started:
Set your action colorspace to AcesCG
Add IBL to your camera
Add a shader node to your geometry and set to Physically Based
Play around.
shiver
February 24, 2025, 7:47am
5
Hello Sinan,
I go exactly this way but there are bugs and glitches in models… strange.
Sinan
February 24, 2025, 7:49am
6
I can take a look if you want to share your setup.
shiver
February 24, 2025, 8:01am
7
Hello Julioleon, I tested with the same models with triangles but same bugs and glitches.
shiver
February 24, 2025, 8:12am
8
andy_dill:
…Other than setting the antialiasing to 96 and praying I don’t think a lot will help. Maybe setting your clipping planes close to the model…For all the amazing stuff that Action does, when it comes to 3d rendering it’s basically a game engine.And to answer the second question: I mostly don’t do motion design in flame. I’m rather bad at it.
Hello Andy,
Wow !
I was in default camera with wide angle and close to objects.
I changed the focal length and push back my camera, and voilà !
No more glitches and bugs to models !
You saved my day Andy !
Thanks a lot !
shiver
February 24, 2025, 8:15am
9
Camera too close to models with wide angle default camera.
I had to push back the cam and use another focal length. It’s ok now.
enni
May 1, 2025, 12:45am
10
Your [near ] camera clipping plane is set to 1.0 by default – set it to anything higher [e.g. 10 or 100… depending on you scene scale]
Ton
May 1, 2025, 11:04am
11
An update 3d engine akin to Blenders Eevee would be sweet…
