Hi guys, perhaps very niche question but it seems that no matter what actual number of channels clip has it always get 3 channels with wiretap. Any ideas if it is generally possible to get a hold on other channels?
the code snippet to check:
def get_wiretap_format(selection):
from adsk.libwiretapPythonClientAPI import (
WireTapServerHandle,
WireTapNodeHandle,
WireTapClipFormat,
clip = selection[0]
clip_node_id = clip.get_wiretap_node_id()
server_handle = WireTapServerHandle('localhost')
clip_node_handle = WireTapNodeHandle(server_handle, clip_node_id)
fmt = WireTapClipFormat()
if not clip_node_handle.getClipFormat(fmt):
raise Exception('Unable to obtain clip format: %s.' % clip_node_handle.lastError())
print (f'num channels: {fmt.numChannels()}')
