Action node - 3d camera/camera analysis corruption
Has anyone experienced using a 3d camera, camera analysis, and 3d shape in action and then everytime since when pulling out an action it defaults to the action node calculating an auto camera analysis and camera track? I have tried switching projects, restarting and nothing. It has made my machine crash 10+ times because of this. Any help would be appreciated.
I don’t know if that’s possible but maybe you accidentally saved your defaults with those nodes? Have a clean Action node and save it like you save your setups but select Defaults from the pop-up menu on the lower left corner of the dialog box.
I would set up an action the way I want it to load every time, then under Node Prefs>Objects&Maps, select Save Current as Default.
@fredwarren I wish more nodes had this option.
Thanks a billion, Tim! This did the trick. Still scratching my head as to how this happened.
This ended up saving that specific action node, but reverted back to corruption when dragging in a new action. Funny stuff.
If you’ve done anything in the Objects&Maps pref, it’s really easy to accidentally set the default.
