For a reason, in all my Flame projects, when I create a new Action node, it comes with an old setup from a batch I created in a previous project, I don’t know even how I did this (by default) implementation from the first place
You have probably used the “Set Current Setup as Default” previously, to cancel this operation. Click Revert to Factory in Node Prefs > Objects & Maps > Default Setup.
For more information: Help
Thanks Philippe, I didn’t even know that I can setup to default, anyhow it is loading clean and empty, many thanks
