You bet your ass I’m keeping custody of Burn.
Somewhere between scraping the Thanksgiving gravy boat clean with brioche rolls and playing DMZ with my teenagers, I’ve been working on getting Flame Batch renders running through Deadline. I’ve always wanted to turn our existing Flame workstations into a render farm without having to dedicate any hardware to it.
Each Linux Flame has the matching standalone Burn 2027.2 components installed and runs a private X display on :98, independent of the artist’s desktop. I’m bypassing Autodesk’s DKU Xorg wrapper at /usr/bin/Xorg and calling /usr/libexec/Xorg directly, with a separate Xauthority cookie and no TCP listener.
A systemd login guard monitors PCoIP and loginctl session state. When an artist logs in, it creates a pause marker and stops the render services. Once the artist fully logs out, there’s a settling period before the private X display and render services come back up. Disconnected PCoIP sessions are still considered active artist sessions for now. The artist always gets priority over the render queue.
On the submission side, a Flame Python hook intercepts the Batch Burn job after Backburner has generated the job archive. It copies the archive to shared storage, extracts the zip/tgz, parses the XML, determines the frame range and submits a CommandLine job to Deadline. I’m running classic Deadline 10.4.3.4 with the repository and MongoDB temporarily hosted on one of the Flames.
Deadline breaks the job into frame chunks and distributes them across the available workers. A custom wrapper invokes the Burn GPU renderer with the XML and assigned frame range, monitors stdout and validates the expected Burn completion message rather than relying on the process exit code. I’ve limited each Deadline worker to one concurrent Burn task because simultaneous Burn instances on the same workstation were occasionally colliding and throwing premature exit errors.
Backburner is still installed and running for Flame’s internal dependencies. One thing I haven’t sorted out yet is reconciling the Backburner queue with Deadline, so Backburner still thinks some of these jobs are unfinished even though Deadline has successfully rendered them.
The latest test completed 1,881/1,881 frames with zero failed chunks across six Linux Flames while I was logged into the seventh. Submissions are coming directly from Flame without any additional interaction from the artist.
I’m codifying the installation, systemd services, login guards, repository mounts, installer hashes, worker configuration, Python hooks and rollback procedures in Ansible. Still some work to do around service accounts, NFS permissions, Xauthority ownership, storage persistence, monitoring and backups. The repository and MongoDB will move to an always-on utility host, and probably the Backburner manager as well.
I’m also looking at adding our Mac Studios. They’re generally logged in, so rather than relying on session state, I’ll need to monitor actual user activity and have Burn yield accordingly. There are a few other things to sort out with Shade mount persistence, consistent media paths, FileVault, sleep and unattended reboot recovery. I’ll test native Backburner/Burn on macOS before introducing Deadline.
Still a prototype, but the Linux side is rendering, the artist handoff works, and I’ve got a bunch of GPUs doing something useful when nobody’s using them. Like heating up the joint.
And by I I mean Devin. There’s still more Chocolate Bourbon Pecan Pie to polish off as breakfast.
