Help!
I’m working remotely via zboost/rgs, hp z8, centos7.6, flame2022_2.
This may not be totally relevant, but I was attempting to install Blender using these instructions:
all seemed good, but when I loggged out and back, the resolution is locked at 640x480(!).
Theres no options in the nvidia x server setup utility to amend this. If I run xrandr in a terminal there are no other resolutions available.
I suspect what may be happening is that the physical gui monitor (in the suite) is off / not responding and so centos is defaulting to a lo-res display setting.
zboost cannot seem to force a higher resolution either.
I’m waiting on someone to have a look locally, but in the meantime,anyone any ideas how to fix this without physically being in the room to check things?
tia
Des
