Burn v2025 in AWS
Is anyone successfully running burn v2025 on a g4,g5,g6 instance in AWS? Ive had success with v2022 (or thereabouts) v2024 for sure, but cannot get v2025 to run.
application fails on frame01 with “unsupported feature” when just using a simple blur. I initially installed the new vers on a previously running v2024 (r8.7) node but it failed. I then created a new node with the same build we use for v2025 flames - based on the ADSK rocky 9.3 release. Same issue each time. Something changed?
I’d first confirm that the Nvidia driver is running properly. nvidia-smi
yes it is - and the same version as the flame - not that that has ever really mattered too much
