To activate/deactivate Compare mode in batch, hotkey is “ctrl + b”
It would be so easy and helpful if the same hotkey gets applied on timeline too…
Opinion??
Opinion??
+1
Having the timeline shortcut for “Show primary track with compare off” toggling between ‘off’ and ‘the last comparemode’ would be great. Maybe we can get enough votes for an autodesk request.
Something broke in 2022 with viewing hotkeys. That’s another subject I guess. Also, the hotkey that toggles between primary and secondary should work when you’re in reels view. Those exact keys that work in player view, they have zero function when in reels view, so there is no conflict. In reels, toggle 1,2 — that should toggle as normal.
Is this why the viewing hotkeys don’t work in Src-Seq mode anymore as well?
Maybe. Something broke recently.
Hi, You can use the hotkey F15 (smoke) to turn on split mode both in batch and the timeline. Toggle between f13 and you can switch in on and off.
