Crock_Ibk
Hi, do your CROK_IBK get cracked like this too? Both dpx files in rec 709 or exr cg get cracked, I hope someone has gone through this to help me, thanks in advance.IBK
Oh yes! I’ve always thought it’s a feature. Just remember to increase the fill hole value to it’s maximum.
I’ve never managed to find a solution for completely eradicating the black holes though.
I posted another print on the link, I managed to cover the black holes, but the matte of the hand reflection looks cracked, I don’t know if it could be the GPU view that is causing this problem
Have you tried setting up the IBK manually as opposed to using the matchbox?
@PlaceYourBetts is the IBK king
Check out his logik live where hes kindly supplied an archive for all the setups.
Best to make your own clean screen first and feed that into the IBK. The in-built keyer is pretty basic and will never get you as good a result.
