Hi all. It’s been a minute since I’ve used Sapphire. Is the latest version color/gamma aware in a meaningful way? Ie if I plop a S_Glow into the middle of a linear comp, can I hit a button or whatever to tell it that it should be working linear? TIA!
I don’t see anything indicating color space handling (at least not in s_glows). It still makes a glow in linear, but it might be a bit…agressive depending on your input.
Nonetheless nothing seems broken, but if you’re going to commit the cardinal sin of applying a plugin at the default settings you may not get the result you want. ![]()
It’s would cost us a boatload to upgrade to the latest Sapphire, so I was just curious if doing so would mean I could use fewer nodes. Sounds like not, which while not the answer I was hoping for is definitely an answer. Thanks, Andy!
