I am getting “a key appears to be stuck, Please release PRINT to continue”. I’ve tried toggling that and all other keys and nothing seems to release it. I’m on Flame 2021.2. Any suggestions short of rebooting?
Was this a known issue? Was it fixed in later releases? Not a big problem when sitting in front of the mac but it can be debilitating when using remote access. Using Flame 2020.3.1. Mac OSX 10.15.7
Some Flame 2019 on OS X Mac users have found that Wacom driver 6.3.22-3 does not exhibit this problem.
The driver has improved the situation but the error message still pops up. It then quickly disappears. Progress.
I get this every single time I tab out of flame and go back.
No matter the version of flame at least a few different Wacom drivers(2 diff tablets), diff versions of MacOS and previously OSX, trash can to 2019 MacPro etc, etc, etc…. Lol
Same here, and also when using a mac to teradici in a linux (currently with a pc keyboard, but also true with mac apple keyboard if i remember correctly)
Yes, on a quite regular basis. But only after I Cmd-Tab into another app and then come back to Flame. On Mac OS. Simple click on Cmd solves it for me. A bit of a drag, but all things considered not a big issue.
In all seriousness, there is probably an easy explanation…
All keyboards generate separate ‘press’ and ‘release’ events for each keystroke. Flame must be receiving the ‘press’ event from the Cmd-Tab, but by the time you press Tab the OS has taken the keyboard focus away and thus Flame never sees the ‘Tab’ or the ‘release’ event of the Cmd key. Hence it determines after some timeout that the key must be stuck.
There should be some way to distinguish that they lost keyboard focus, or have the Cmd press timeout after 5s or some reasonable amount of time, as a Cmd-Tab means you’re likely spending extended time in some other app before coming back to Flame.
I do a lot of remote connections, even in-house, from Linux to Mac over AnyDesk, from Mac to Mac with ScreenSharing, and usually experience this is when remoting between systems…
