Flame linux reset
Is there some secret way to reset rocky 9 back to “just installed”
Did a idiot thing by running Install_burn_headless but I forgot that it has adisplay dongle and now burn wont render anymore and nomachine is freaking out and everything is broken.
It comes with a warning that i skipped over so now reinstall time (boo)
its my own fault so yay
@finn - not immediately.
you can try:
ssh to the machine.
sudo /usr/local/bin/rmsoft
(let me look for the headless option)
the headless option is -g
so:
sudo /usr/local/bin/rmsoft -g
then reinstall the DKU
then reinstall flame
then reinstall your remote control software.
this is about 12 - 20 minutes.
you could even try:
sudo /usr/local/bin/rmsoft -fag
or
sudo /usr/local/bin/rmsoft -fagcv
Usage: rmsoft [option]
Options:
  -h, --help            show this help message and exit
  -a, --all             Remove all Autodesk software
  -r RESUMES, --resumes=RESUMES
                        Remove Autodesk software associated with either the
                        resume file or the regexp string specified
  -k KEEP, --keep=KEEP  Remove All Autodesk software except the one associated
                        with either the resume file or the regexp string
                        specified
  -f, --delete-folders  Remove all autodesk FOLDER
  -c, --no-confirm      No confirmation
  -g, --no-gui          trigger interactive shell mode
  -v, --verbose         verbose mode
sweet trying that right now!
Delete the Xorg
yea… tried that, down the rabbit hole, i uninstalled it all, recreated a new xorg, nomachine now just shows me “oh no! something something” broke, i did a bunch of random stuff now with xorg, reinstalling nvidia drivers, restarting gdm, but its just not working at all… i think install_headless really does some crazy damage
It installs VirtualGL, which would definitely make things fucky. You could try dnf remove VirtualGL
yea there was more weird configs with virtualGL, removing it using the nomachine app actually worked!
i am so close now the only thing I still get is
Users reported that: When launching Burn jobs to a Burn node that has no desktop session started, the render fails, showing the error:
Fatal: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
so its not technically headless, as it does have a display connected (dummy hdmi dongle) if I login to nomachine i get echo $DISPLAY = 1 and my flame config also has that, so that works… just BURN wants to not start
I think I am giving up and reinstalling the system tomorrow, man this is so weird, everything else runs, houdini e.t.c
i really dont know how this is supposed to work with a non headless workstation thats used for both burn as well as regular remote sessions. I dont even want to run flame interactive but other things.
i can get it to launch a session as display:0 but that doesnt seem to solve burns issue either, I guess burn runs as root? should I just auto-login root as tty2 on display0?
I don’t know about NoMachine, but when in Teradici mode, Burn does not run. But when using NiceDCV, yes, Burn works. So I suggest you test that, and make sure to use the latest 2024 version of DCV. I tested a pre-release fix this morning, not sure when it will make it to the general public.
uninstalled nomachine, did a bunch of reboots, made sure root does autologin to root and some other shenanigans and behold… it works :slight_smile:
