Has anyone run into the issue of importing a clip with say 140 frames, but when pulling it into batch it converts it to 91 frames? It reads correct in the timeline, but when I pull it into my batch it removes frames. Anyone experience this?
Or perhaps there’s already a 91 frame clip in the batch that has set the batch duration?
Tragically no set in/out.
The 91 is an outlier. But this is also being prepped through premiere, so there’s very little info I can get from the clip itself. I wonder if it’s some how being contained within 91 frames. Not even sure that is possible.
Is the clip the same framerate as the Batch?
