Jogging audio
I remember back in the day, you could jog the audio, but unless I’m missing a trick, you’ve not been able to do this for a while.
or in smoke keys it’s
shift ctrl c or v
So not with the pen?
The shortcuts highlighted by John will move the positioner by X amount of frame (1 by default). If you search for scrub in the keyboard shortcut editor you should also see the modifiers to use while you drag the positioner:
  • Scrub Current Audio Track
  • Scrub Current Audio Tracks with Locked Rate
  • Scrub All Audio Tracks
Hi Paul,
ALT (OPTION)+Click and drag is the digital scrub.
CONTROL+ALT(OPTION)+Click and drag is the analogue scrub.
Hold K and tap L or J digital scrubs one frame forward or backward.
This has always worked as long as I remembered.
Hope this helps!
Grant
I also forgot to mention that when the focus point is on a video track, you hear all the tracks scrub together.
However, when you move the focus point to a specific audio track, you only scrub the contents of the targeted audio track.
I found that really handy when trying to scrub a segment in an audio mix.
Grant
Thanks guys. It’s been quite a while since I needed to scrub audio, I probably forgot the hotkeys.
Frederic, how do I change the default one frame setting?
You can change the assignation from the Keyboard Shortcut editor.
