Keying issues -> my first foray into colour mgmt 😫
Hi guys, getting some shitty edges as soon as I comp some well-shot green screen over a purple background, and I suspect I’ve stuffed up my colour settings.
Forgive me, I’m a total colour n00b.
So I’ve started a project in 2026.2.2, and selected Aces 2.0 as my default project setting. First mistake, but I really need to learn this stuff so why the hell not.
My footage is 6k Sony Venice, and inside Action it inherits the SLog 3 Venice-S-Gamut3.cine LUT.
My viewer is ACES SDR 100 nits by default. I’ve got a purple gradient in the BG managed to the Venice LUT so they match. Trouble is - I’m getting a horrid pink edge around my key. Why is that and how do I fix it?
Thanks!
despilled fill:
result (with some grading via image node/CW etc):
Can you explain this part a bit more? What is the source colorspace of the purple gradient? What transform are you using to push it to sLog?
Thanks Ryland, I changed it in the Gradient node prefs menu. :slight_smile:
Actually Ryland - your question made me think that was the problem, and so I set the CM inside the menu to ā€˜from source’ and then did the conversion inside a CM node instead, and it’s fixed! Thankyou! Why did it do that though?
Not super familiar with the gradient node. I just played around with it for a few minutes to try and make a purple gradient and I pretty quickly got myself into a place where the values were exceeding one. Log values over one generally don’t play nice. Probably something to do with that, but since I rarely comp in Log, use the color picker for creating colors, or use gradient, I’m not really sure.
I never really stopped to think about it before, but I guess color source and gradient don’t really have a colorspace? They’re just raw values so the Tagging menu is just about how theyre being displayed to you through the viewer. If you set RGB to .5 and cycle through the tags it will adjust the display values but the working values don’t change. My guess then is that you had values either over one or below zero and applying an input transform from aces to sLog brought those values back into a range where they would play nicely with your source image.
Thanks for that, I figured it was a illegal colour thing and did initially try clamping but none of that made any difference at all. I don’t really know enough about colour but at least I know enough to get by now, thanks again!
As a wise woman once told me, ā€œColorspace never takes a day off.ā€
A little gotcha with the gradient node in linear space (not sure if you are doing it in linear or rec) high luma levels print through into the gradient if attached to the clip.
my hunch is it was because you were tagging images instead of converting them.
Scene-linear, log, and video images all looking correct via tagging, but retain their wildly different pixel values (10.0 white in linear, 0.68 white in log, 1.0 white in rec*, for example) so when you try to combine them and then view the result through a viewing lut, things will go wonky.
It seems like you worked it out with a CM node set to input transform, which is indeed The Way (insert baby yoda gif).
Generally I try to get everything into ACEScg and go from there. In some cases I’ll work with the camera’s version of scene linear. Somewhere back in like 2020 there was a thread about moving between ACEScct and ACEScg for various tools but I can’t find it so here is the one-sentence version:
Do all compositing work in scene linear and all color work in log.
You could make a case for keying in log, although I’d still do the actual comp part (after generating a fill and matte) in linear.
*whitepoint color values are approximate.
I think I copied this from a thread from you andy_dill at some point. I remember you did a video that was helpful a few years back. I often find myself referring to it…
Operations That Work Best with Scene-linear Colors
The following operations work best with scene-linear colors (that is, with code values that are directly proportional to light energy in the scene):
  • compositing and blending
  • optical effects, including lens blur and defocus operations
  • motion blur
  • anti-aliasing
  • resizing
  • sub-pixel repositioning
  • 3D rendering
  • lighting and re-lighting
Operations That Require Video Colors
The following operations require video colors (that is, color values that are restricted to the range [O,
1]):
  • color inversion
  • converting RGB to HLS, HSV, or YCbCr
Operations That Work Best with Video or Log Colors
The following operations work best with video or log colors:
  • many color correction operations
  • vectorscopes and histograms
  • tracking and stabilizing
  • grain and noise operations
  • unsharp masking
  • video transitions
  • making gradients
Hi Grant!
Those two should (broadly) be in the log area, not linear. The reason is that certain resize kernels will apply sharpening that can go negative when the difference between adjacent pixels is too extreme. It usually manfests as oddly colored pixels next to bright lights, or overly crunchy edges.
Hi Andy,
I can’t actually remember exactly where on the forum I got the list from originally, but thanks, good to know!
Yeah, I went looking for the thread yesterday myself and came up empty.
It’s from the Flame user manual :slightly_smiling_face:
They have to move resizes to log!
You’re right, doing a resize in scene-linear space is prone to artifacts from kernels that have negative coefficients. I will submit a change to fix that (though I’m not sure if they’ve already pulled the content for the next release yet).
Any day something we wrote could be mistaken for something @andy_dill wrote is a good day. :wink:
Haha. I was flattered I’d been conflated with official literature.
