Logickeyboard issue
Hi everyone,
Is anyone using a Logickeyboard on macOS?
I recently bought a Logickeyboard for DaVinci Resolve, and I’m having an issue with keyboard shortcuts. When I hold Space, the Pan tool is activated as expected. If I then press Control while still holding Space, the viewport zooms, which is also expected. However, when I release the Control key, the Pan tool doesn’t switch back to the Pan tool, even though I’m still holding Space. It only starts working again after I release Space and press it again.
This issue only occurs with the Logickeyboard. If I use another keyboard, everything works as expected.
Has anyone else experienced this issue or knows how to fix it?
Are you working locally, or remoting in?
-Ted
In both ways the same
For reference, here’s the keyboard I’m using:
The keyboard shortcuts are working as expected - I can hold space to pan, add control to zoom, and release control to resume panning.
I have the keyboard plugged into my Mac trash can at home, and I’m remoting into a Mac Studio at work.
-Ted
Thank you, Ted. I contacted LogicKeyboard support, and the they promised to fix the bug specifically for my setup on Mac by updating the firmware and replacing my current keyboard. We’ll see how it works once the new keyboard arrives.
