Logik matcbox shaders
Hi,
Does anyone have a link to the latest Matchbox Shaders Collection ?
Thanks in advance,
Matt W
https://logik-matchbook.org/
Downloaded on 8 march
maybe it helps for now.
@ytf
unfortunately i can’t get a connection to the server
Thanks but sadly the link is broken.
:wink: xx
That’s been an ongoing problem that should be solved somehow. The site exists and is fine, but it frequently gets overwhelmed with traffic and then can error out for days at a time. It has become an unreliable resource.
If you install LogikPortal, there is an option of ‘Download All’, which I believe uses a copy and doesn’t interact with logik-matchbook in real-time. I’ve been able to install from there when the main site was down. Not sure how often that copy refreshes?
thanks for the help!
I checked it before I sent it. It was fine.
I’m sure it works for some, but not others. The error message specifically is from CloudFlare, which is a geo-located CDN, that it cannot refresh it’s cache. So the problem will differ by location.
I tried it earlier and just now, and also get the 502 errors. I get them about 50% of the time I try to go to the site over time.
Hi there. What would be the right way to update a matchbox on the Logik Matchbox site these days? I just made a tiny but usefull (for me) update to Ivar’s Crok Blush that I would like to make available for all.
I’ve only ever updated my own, not other’s. But I think the process is the same
Go to ‘Share your shaders’ on logik-matchbook and drag all the files in. It does some QC on the back end and then adds them as a new version.
Thx I did that and it worked. Cool
