New Python Scripts
Ab Colorchecker v3.9.2
Camera matching via Macbeth ColorChecker chart in ACEScg scene-linear.
Masv Uploader
Multi Batch Render v4.15.0
Wave Parabolic
# wave_parabolic What it does: Sawtooth ramp shaped by squaring (eased parabolic ramp) scrolling with t.
Flame: 2027.1
Wave Triangle
# wave_triangle What it does: Scrolling triangle wave (linear up/down ramp); wavelength period, animated t.
Flame: 2027.1
Normal To Facing
# normal_to_facing What it does: Facing/rim ratio from a view-space normal pass (Front 1): rim 0=facing (toward camera), 1=rim (edges), falloff shapes it.
Flame: 2027.1
Pmatte Rays
# pmatte_rays What it does: Radial rays on the X-Z plane around (cenR,cenB), rays count.
Flame: 2027.1
Normal Relight
# normal_relight What it does: Lambert lighting from a normal pass and a light direction (lx,ly,lz).
Flame: 2027.1
Pmatte Rings
# pmatte_rings What it does: Concentric 3D shells around the centre point, spacing ringScale.
Flame: 2027.1
Pmatte Sphere
# pmatte_sphere What it does: Spherical matte in 3D position space around (cenR,cenG,cenB), radius prad.
Flame: 2027.1
Logik Portal v7.2.0
Despill Blue
# despill_blue What it does: Reduces blue where it exceeds the red/green average; spill 0→1 sets strength.
Flame: 2027.1
GFX Sync v1.0.0
Sync the text of Flame Type (Timeline FX) graphics across many sequences and aspect-ratio versions from one place.
Smart Batch Autosave v1.0.2
Background auto-save engine for Batch setups with a PySide6 settings UI.
Frame IO
FrameIO Integration for Autodesk Flame A comprehensive integration suite for connecting Autodesk Flame with FrameIO, enabling seamless uploads, comment synchronization, and project management within the Uppercut VFX Pipeline.
Collect Media v1.0.2
Dump a list of every non-cached clip and segment in every sequence and batch in every folder out to a known location for archiving.
Ffmpeg Transcode v1.0.0
Transcodes the selected .mov files to .mp4 using specified bit-rates from both audio and video when the supplied profiles don’t match a delivery specification and you want to avoid the likes of Media Encoder, etc.
Tag Tools v1.5.1
Manages tags on sequences to be used later in QTs with the objective of being able to track original sequence name from Flame vs client name as well as audio.
Nano Banana v1.2.0
Uber Save v5.1.0
Thank you for your service.
Uber Slate Maker vv2.6.0
